- Mar 1, 2003
- the terran system
Over the past month that I have been with this forum I have seen many questions about what 80mm fan to use. This is for those who are new with cooling and not sure what fan to use.
These recomandations are just my opinions so you all have every right to disagree with me. Just dont start huge arguments or debates about wich fan is better.
I recomend these fans
1.Thermal Take Smart Fan 2 80X25
20.55 cfm @ 1300 rpm 17db
75.7 cfm @ 4800 rpm 45db
also, it generates for static pressure than the vantec tornado from what i heard. meaning it is better at ramming air through thin finned heatsinks.
this fan is about $10 but comes with a 3-4 pin adapter, a nice looking laser cut fan grille, thermal tape, thermal adhesive, a temperature sensor(plug in to fan and fits in case or underside of cpu), screws, a rheostat and a color instuction sheet.
the reasons why I like this fan is because it moves alot of air for the amount of noise it makes, it has 3 functions, and the fact that you can control it from 1300 rpm to 5900rpm. at 5900 rpm it makes more than 45 db of noise but probably moves close to 90 cfm of air.
2. Sunon High-Speed a.k.a. Vantec Tornado 80X38
84.1 cfm @ 5700 rpm 55.2 db
This fan is about $10 as well but is much larger than the Smart Fan2. this fan also comes with a 3-4 pin power connector.
This fan is very good for cpu cooling ( smart fan 2 is good too) this fan has alot of power to be able to ram the air through thin finned heatsinks and is good for overclocking. The one problem this fan has is NOISE. It is VERY LOUD.
3. Sunon 80X25
39 cfm @ 2900 33db
This fan is for those of us who are on a tight budget and just need a cheap reliable fan. This one is about $3.50 (not the cheapest out there but the price is resonable for what you get)
this fan moves a reasonable amount of air for its noiseand PRICE. These are NOT good for cpu cooling UNLIKE the other two.
I hope all this helps those who are a bit new with the whole cooling thing.
3. Sunon 80X25
39 cfm @ 2900 33db
