im VERY glad to hear everything worked out. was it the grills?
im cutting mine off on thursday, so i hope i see a drop (if it really is a 65% brop, than of the 100cfm of airflow going through, im only getting 35, eeeew
this is what made the biggest difference in mine. I was running a blistering 165 degrees farenheit on my processor with a 30 dollar thermaltake cooling unit. I put this cooler on my machine and it dropped 65 degrees just like that. Its fan runs at 1000 rpms less than the delta. I wonder if you could put a faster fan on it? Hmm.... anyway there are several reviews on it one review with 10 of the newest coolers head to head. CHECK IT OUT!!! later
I dont know why that posted twice but anyhow I just did some comparing on the Heat Pipe and and the Volcano 7
Volcano 7
Fan Dimension: 80x80 cm
Max Air Flow: 46 CFM at 2900 rpm (this is the lowest possible)
Heat Pipe
Fan Dimension: 60x60 cm
Max Air Flow: 36 CFM (this is what is listed on the web page)
Hmm they dont quite match up unless that heat pipe makes up for what it lacks compared to the Volcano7. The concept makes sense, but actually performing is different.
yeah thats what i thought was soo neat about it. its fan isnt as big and not near as powerful and yet it cools just as well or better from the reviews ive read. But, we all know how reviews can be. None of them are the gospel Its a very good fan though if you go to www.coolermaster.com or coolmasters.com i cant remember, there are reviews everywhere about it and they arent done by coolmaster they are from magazines and things like that .. cya
