OK People, Wedo made a good point I forgot to mention I also have an exhaust fan in the back of my case. Now that is important but even more important is cutting the built in screens out of your case. The screens block 65% of the airflow coming in and going out. Yes 65%. If i was 65% malnutritioned I would be in a world of hurt. Just like your computers without proper inlet and outlet holes. Ok now, here is my setup as of right now. I was playing around with a harddrive cooler in one of my slots but I took it out. ECS-k7s5a
gigahertz t-bird overclocked to 1032
256 meg of 2100 ddr pny ram
soundblaster audigy platinum
nvidia gforce4 ti-4400
maxtor 40gig 7200
plexwriter 40/12/40a
liteon 40x12x48x
KDS 19 inch Avitron
if i left anything out
sorry now for my cooling.
2- 80mm intake fans in the front
1-80mm exhaust fan in the back
harddrive cooler on harddrive
fan on video card obviously
THE HEAT PIPE on my processor
and obvious one in power supply
THATS IT!!! RESULT= 37degrees celcius on chip at idle
27degrees celcius board and case temp
41degrees celcius on chip under load
30degrees celcius on on board and case under load. Thats with like 8 programs running in taskbar plus playing resource sucking games like renegade.
OH ONE OTHER THING. IF YOU DONT LIKE HEARING THE FANS BLOWING AT YOU, YOU CAN ALWAYS GET A CASE WITH A THICK PLASTIC COVER AROUND THE SIDES AND THE FRONT. I HAD ONE AND IT WAS VERY QUIET. WHEN I TOOK ONE OF THE SIDES OFF IT SOUNDED LIKE AN AIRPLANE LMAO L8R ALL!
