- Apr 25, 2010
Details now:
Case; just a container, HAF has plenty of air flow, saves some change
PSU; almost identical, slightly cheaper, still great brand
RAM; if all your doing is gaming spending on hella ram is silly IMO, get good ram, but 4gb is plenty and you dont need super expensive stuff
SSD; your not gonna load a ton on the SSD, OS, browser, maybe 1 or 2 other programs so a smaller one will hold what you need it to pretty easily. SHoot a 60GB takes cost down another 40 bucks to 124.99 and it will easily hold OS broswer and a couple other programs... you dont NEED a huge SSD to get the benefit realistically, its a luxury past your OS realistically.
OS; what does pro have that home edition does not that you NEED it to do?
CPU COOLER; you could even go cheaper but if you plan on a good OC this is very highly regarded, heck you could get the hyper 212+ in a push pull fan config for like 50 bucks, its very good bang for the buck
GPU; dont buy a factory OC'd card unless it is on sale, no reason to believe you cant do the same OC yourself, and no reason to believe that card NEEDS to be OC'd right now
Hope that helps some
ssd performance really depends on what game you are playing. ive been playing oblivion on my 3d monitor and having it installed on my ssd instead of a hard drive really smooths out the gameplay when moving between areas. i think 60GB is the minimum to get. if you need more space you could get another in a few months when technology changes again and the price drops.
