- Nov 22, 2001
- Blacksburg, Virginia, USA
>>Pick your poison<<
Thanx a lot.
Thanx a lot.
Garfield said:Thanks. And, anybody have a logo we could use? You will get credit
XWRed1 said:If you ask me, I think you should come up with a simple yet meaningful design.
The simpleness would allow it to be represented in alot of different mediums, and give the artists the choice of prettying it up.
Garfield said:Yeah, I guess I can see where drunkmonkey is coming from. When you did shrink it into the icon, it was hard to tell what exactly it was. Thanks all the same!
Garfield said:I was thinking lion, but if you have any other thing that doesn't have to do with lions I will consider it. Thanks, IdeaMagnate! I appreciate that. drunkmonkey, did you get my e-mail?
drunkmonkey said:I found a bug in ur source:
Line 43: AttSuMsg should be AttSucMsg right???
I'll update the source on the page when you say OK, just to make sure.
