- Mar 27, 2011
- Soviet Mexico
Your going to need to insulate better where the single stage meets the the water block. Otherwise your trying to cool the entire room and not just the block next to it.your also probably gonna want to insulate your water lines. This should help control both the condensation, and the amount of condensation you have going on. Some Pipe Insulation from the hardware store should do the trick.
