Hello!
I have a few months experience in overclocking numerous systems,
I work at company that build-install-test-oc's computers in the UK Im an apprentice and Ive come here to learn more about the settings I use because I get a lot of mixed messages at work.
I'm going to talk start off by talking about the two most common boards I overclock on; Gigabyte z97 and asus z97, and the cpu - i7 4770k (if this post progresses I will most likely start reffering to 4790k.)
Basically when I first started I was taught two sets of settings for these two manufactures, (mainly because of their wordings and language its obviously going to be slightly different).
I will First start with Asus z97 4770k 4.1Ghz
Go to Advanced mode - Ai tweaker
Set Ai overclock tuner to XMP if available
CPU core ratio - Sync all cores - 41
CPU core voltage - Manual mode - 1.175
Then enter DIGI++ and set
CPU VRM Switchin frequency - 350MHz
CPU phase control - Optimised
CPU power duty control - T.Probe
Now Gigabyte z97 4770k 4.1Ghz
Performance -
Frequency
CPU clock ratio - 41
Enter advanced cpu core settings
Uncore ratio - 38 (for 4670k) 39 (for 4770k)
Voltage
CPU Vcore - 1.175
Recently we've had a change in management and he's taught me a different way which is as follows
Set Ai overclock tuner to XMP if available if not Manual
CPU strap 100mhz
PLL selection - LC PLL
Filter PLL - Low BCLK mode
Sync all cores - 41
Min & Max cache - 41
Internal PPL voltage - Disabled
DRAM Freq - 1600 or whatever freq RAM is
CPU core voltage - 1.175
CPU spread spectrum - Disabled
Load Line Calibration - Level 3/4
CPU current capability - 110%
Performance -
Frequency
CPU Base Clock - Manual
CPU PLL Selection - LC PLL
Filter PLL Level - Low
Uncore ratio - 41
Voltage
VRIN External Loadline Calibration - Standard
CPU Vcore - 1.175
My first boss seems to have simple basic strategy that worked as we do around 50 systems a day we need to have a fast and quick strategy we can follow...
So my Questions
My new boss is saying always have cache and cpu ratio 1:1 cpu core ratio 40 - max cache ratio 40, cpu core ratio 41? max cache ratio 41 etc etc
My old boss disagrees and I've watched a lot of videos and done a lot of reading and Asus are saying 1:1 ratio is best for performance but hard to achieve stability and its better for max cache to be 100-300mhz below the CPU core ratio they go on to say they achieved best results with a max cache of 39-40?
Why is my new boss convinced otherwise?
Is it because we rarely OC past 4.1-4.2Ghz so we can achieve stability easily and still get the performance benefit from running the CPU cache-core ratio the same?
(Even though I have heard this performance benefit is minimal)
Also
Does CPU strap 100mhz, PPL selection - LC PLL, Filter PLL - Low BCLK mode ...add stability? If it doesnt why does he use these settings?
Loadline Calibration?
From what I've learnt and please correct me if I'm wrong that when you set you're Vcore the intel chipset drops the voltage a bit to protect the CPU creating Vdroop.. So you set you're Vcore in the bios to say 1.4 and when you're idling in windows CPU-Z will read 1.4 however under load it will drop to say 1.36 due to Vdroop.. LLC counteracts this by boosting the Load voltage up to idle voltage however having a too high load line overshoots the idle voltage? For example 1.4 may overshoot to 1.46 at level 8.
So is what I've just said correct? Also how do you select the correct Level? Level 1-8 on Asus or on Gigabyte Regular, Standard, High, Ultra High, Extreme
Also CPU current capability
My new boss briefly set use 110%, use higher for higher overclocks? Does this help improve stability? Would 120% on a 4.0Ghz overclock make it more stable if I was struggling to reach stability (I'm guessin it would waste a lot of power and create more heat and should be used for 4.3GHz plus?)
Also CPU VRM Switchin frequency - 350mhz
My old boss used to say above 4.3Ghz use 400mhz my new boss says always 350.. however I see some boards go up to 500mhz (was the sabertooth z97 mark 1 I was looking at).. I was reading a lot about VRMs the other day and surely the higher switching frequency the better would it not reduce ripple voltage on the signal or is it strictly the amount of phases the mobo has that does that? Is 350mhz enough and 350+ is more motherboard manufacturers showing off they can get 350+?
And more also's lol
Also is there anything else that can be done to increase the stability of the overclock? Another guy came over the other day and increased the CPU VRIN External overide voltage to 1.9 (I believe it to be 1.8 at stock) he said this helps stability but said not to worry about it
Also I've seen Asus talking about CPU I/O voltages and Cache voltages can they be adjusted to improve stability I'm sure that was what he was saying on youtube yet that it wasn't that higher or lower was better just some CPU's prefer certain voltages (think this was I/O voltage)
Are the other settings you can adjust to help improve stability?
So please answer all question and I'm grateful for all you're answers however please refrain from just tellin me to up the Vcore I'm well aware lol
Performance -
Frequency
Voltage
CPU Vcore - 1.175
CPU strap 100mhz
Sync all cores - 41
Performance -
Frequency
Uncore ratio - 41
Voltage
CPU Vcore - 1.175
So my Questions
Also
And more also's lol
