Hello to everybody, I am looking for a help with an old lady motherboard (DP55KG) that I don't want to give it away and I face problem after I changed the cpu of I5-760 with zeon X3470.
With the I5-760 was able to operate 4 dimm slots with 1600ghz speed by keep deactivated in bios the intel boost frequency and using xmp profile on 1600ghz. Same adjustment doesn't
work with X3470. With 2 dimm on the 2nd channel working good but when I install 4 dimm the motherboard starts and after 3 seconds power off and same again goes from start and power
off. (I also mentioned that motherboard has two leds above sockets that one is lighting before motherboard power off due to the problem. this led is the voltage regulator). Any help will be high
appreciated from the forum.
