Ive managed to get my 1100t BE to run at 4ghz and the temp is 50c with Hmonitor. My vcore is 1.512 max and 1.428 min. Ive got it set lower in bios but llc is bumping it up as with it turned off it crashes. Thanks
You can post a picture of your HWMonitor window when the processor is loaded to remove any confusion. Personally I aim under 55 on the cores though I've seen some claim 62.
To attach pics, first crop and save the images with Snipping Tool in Windows Accessories. Then click on Go Advanced at the bottom of any new post window and when the advanced post window appears click on the little paperclip icon at the top. That will load the file browser/upload tool. The rest is obvious.
Make sure you run Prime95 for the full 20 minutes. The peak temps will occur at about that point. But it looks like both you core and CPU (socket) temps are just fine. Looks like you may have 5-10c temp room if you need to add more vcore. Now you need to see if the system is stable for a long (at least 2 hrs.) Prime95 blend test to be sure your are really there.
I ran it for 35 minutes and it scrambled screen and restarted. Iam going to up the voltage abit and try again. It seems to work better with LLC but the voltage jumps from what is set in bios. Thanks
That's what LLC does and why it's a good thing. It only supplements the voltage when you are doing heavy load computing and need the extra voltage for stability. I would leave LLC implemented to some degree. Otherwise, you will be running 24/7 on the high voltage you need only for heavy duty computing.
By the way, unless we direct otherwise pleas post pics of these three CPU-z tabs together: CPU, Memor and SPD. That will give us a more complete idea of your system settings. Just to post the CPU tab tells us nothing about your ram.
