bizkonson
- Nov 6, 2012
hi all,
im a bit new to the whole overclocking world and on a personal note its been years since i was updated on anything that have to do with pc hardware :\
anyways i built me a new Mame cabinet and building a nice size power pc inside
this is my specs so far:
1)Motherboard - mci p55 fuzion
2)CPU - i5 750 2.66 currently running at 3.3 with lower then default voltage (not using OC Gene) but might give it a test run down the road ive read it give great power boost but uses a lot of voltage on the cpu)
3)Graphics card: ATI HD4870 1gb black series (i dont need a great video card since this rig is connected to a 27" CRT)
4) 2 x 4gb ddr3 ram 1600
5)currently i have 2 system fans 12volt and the original cpu fan (thinking of replacing it to a better one because the machine does run pretty hot with full stress test between 70c to 80c and as i understand if ill up the voltage back to the default and not the lower that was set for me it will take the temp down? is that correct?)
6)1 HD sata 1tb. no cd no exterior hd.
my question is what power supply should i get for it will the 500 or 550 be enough i might play with more over clocking later...
thanks in advance
Biz
thanks in advance
Biz
