- Dec 19, 2000
The probes are similar to the idea I mentioned above. The only difference being the use of a submerged heatsink instead of a probe. 15c seems a bit off for such a low watt TEC. If the system were at stock everything that might be possible. Building your own looks a bit cheaper.
Low power TEC
2 heat sinks
1 decent 80mm fan
A reservoir tapped into your water if you don’t already use one
RTV sealant
4 hex head screws
The low power TEC uses the heat sink / fan to keep the hot side cool. The second heat sink will reside inside the reservoir, directly fastened to the cold side of the TEC using 4 hex screws. Use RTV sealant for everything that needs protection from water. This is not something I thought up entirely on my own. I forget who it was but someone here at OC did something very similar with respectable results. If I remember correctly it dropped water temps 5-7c! That’s a nice improvement for not much work. You don’t even have to worry about condensation until you get a lot more TEC power.
Low power TEC
2 heat sinks
1 decent 80mm fan
RTV sealant
4 hex head screws
