- Jun 22, 2002
- Asheville, NC
Drench it in Marine goop?
lol Thats what I would do.
camel said:Any way to get a large washer, and a nut on the inside of the Res for the barb? That should give it a larger area for silicon, and spread the load a bit when the barb is tweaked sideways, and whatnot. Maybe a large washer on the outside also, sandwiching the plastic with lots of caulk
userA said:
When I built my reservoir I have to sandwich 2 large washers inside and outside on a thin plastic bottle to help spreading pressure (when pushing/pulling tube to/from the barb), and get better sealing. I use a Step-Drill (about $25 from Homedepot) to drill the hole (a picture of the Step-Drill is shown on the "Water-cooling Reservoir Theory and Construction article on the front page http://www.overclockers.com/tips1089/index05.asp). It worked great for drilling a big hole for a 1/2" NTP barb on a thin plastic.
