This is about the 3rd time ive read this thread, did so when I first got the mobo and now as a member. If I may add to the thread..
Having owned it for about 8 months and spent everyday with it, I have become fond of it! Sometimes I do think about buying a CHVF to see the difference, or see what else it has to offer.
A few issues I have with this mobo are;
1. No decent fan control - settings are basically all or nothing
2. LLC is 'backwards' compared to every other mobo (you mentioned) but disabled seems to be like 'extreme' LLC on other mobos.
3. The bios gets stuck sometimes on a loop lock - reflashing fixes it or if youre lucky clear cmos button (this is rare but reported often)
4. with 12 phases on the cpu, I wonder if a single 8 pin connector was enough.
Some problems that occurs when ocing, I appear to hit some kind of OCP or OVP, over current/over volt protection. When at full load, anything that stresses all 8 cores too much the mobo shuts off/hardlocks and needs power cut to restart (error 00)
this happens when above a certain voltage and the frequency has a minor impact.
example, single core benches allow me to bench upto 1.75v,
Prime95 has a limit of 1.53v,
cinebench 1.65v,
3dmark physics 1.61v
I haven't got 5ghz prime stable as it locks up, the most without locking up is 4.9ghz, no matter how low I drop volts, LLC or whatever I try
maybe its the cpu, possibly psu or temps. (but temps are good)
but on the positives, its absolutely given its all in benching. I know the cpu has to take a lot of credit, but its beaten and shamed CHVF's
the latest 1.95A bios is a physics god, about 10% better compared to any before.
its been crunching weeks solid without bsod, crashes or heat issues (usually at 4.875ghz added more vcore to eliminate errors)
the VRMs are more solid than anything I know, ability to turn on thermal throttle and it still not throttle... they stay cool at stock speeds, but when modded with a fan, literally any speed they stay cool.
It can handle a decent RAM speed (max ive has is about 2650mhz benching)
can add cpu VDDA and PCIE VDDA. allowing better stability for benching
and it handles xfire extremely well
great article Rgone.
(I just got to work out that damn hardlock problem, maybe soon itll be subzero for the first time on the net)
