Hi all. In all my years of computing, I've never actually had a "dead" mobo before... but I think I do now. Just wanted to run it by you guys before I spent any $$.
Basically I was pretty sure I left my PC running for some downloads to finish. At night I went down to turn it off, only to see it was already off. Ok, whatever, I guess I did shut it down (I thought). Next morning though... go to turn on, and nothing. No lights, no sounds, no fans... nothing.
My first thought was the PSU. But I did the "short green wire to ground" trick and it fired right up. I installed it in my friend's PC and it turned on no problem. So PSU is confirmed good.
My second thought was perhaps the case's switch, so I tried shorting the mobo's POWER_SW pins... nothing.
Am I right in then concluding the mobo is toast? Or could it possibly be the CPU or something else? I would think even without a CPU or ram I'd at least get something. The mobo has onboard LED diagnostics to get error codes in case of a non-post, but NOTHING comes on, including those LEDs. Zero power at all.
Any thoughts/tips?
Supposedly I have a warranty. I bought it 15 months ago and it has a 2 year. But at best that takes several days to fix and its tax time! I need this up and running ASAP.
Cheers.
- Steven
Any thoughts/tips?
Cheers.
- Steven
