- Oct 5, 2008
- Cumbria (UK)
The corsair 650/750's are quiet units correct?
Yes, mine is whisper quiet. (Rig in sig)
The corsair 650/750's are epic units correct?
I have the OCZ. I picked it up at the time everyone was yelling to get the OCZ. Now it suddenly ranks with Raidmax?
Here is what I suggest, pick one:
1) Corsair
2) Corsair
3) Corsair
Depending on the amount of hardware he has on his rig, I'd suggest the TX650 or above.the corsair 650 will do you well. you could probably squeak by with the 520w model tbh but better off with the 650.
No, it doesn't. It has 3x 18amp 12v rails. Total of 54 amps.The HX520W has a peak efficiency of 80% @ 318W, 18A @ 12V. Input current 9A(not so great since some newer graphics cards like 25Amperes input.
The thing is, the TX650W has a peak efficiency of 84.2% @ 380W. 52A @ 12V. Input current 10A
From what I understand, it is one total rail.Aren't they "fake" rails, anyway? I thought every cable was drawing from the combined total of 54A.
Lol, I can't see ANY 1000W PSU being quiet dude....
No one recommending a Seasonic? Seasonic makes incredible PSUs, and most are very quiet. Though it does seem they're a little pricier. Do you really need 750w? Is that what the GTX275's demand?
