- Oct 9, 2001
- Cheyenne, WY
Perhaps the issue is not hardware related?
Microsoft, in their infinite wisdom, made a serious design flaw in the Windows install process. When you "format" c: during the install, Windows doesn't "format" anything, it simply removes the file location directory (e.g. File Allocation Tables).
To add, during the install process in Windows Kernel v6.0+, it will take a quick look at the drive to see if any core files exist and use those.
That creates serious problems when core files become corrupt (as you mentioned the update process to be symptomatic).
The best cure is to use a bootable program like DBAN (Security wipe software) and run a Quick Wipe (1 pass, all bits to 0).
Windows will then truly install a fresh copy.
Solved many, many odd issues I've seen at work that caused Windows to repetitively fail.
