- Jan 12, 2015
Was having this problem:
Logitech G Hub "Connect your Logitech gear" when the keyboard was changed to a different port. Switch the keyboard to any other USB port and it shows up just fine.
To be clear the keyboard was working in that port, but Logitech G Hub would not recognize it there.
The printer I use would also not work in the that port, causing me to have to remove the keyboard in order to print.
Checked the driver, and the keyboard would install as "ROG Virtual HID" in that one port.
Some internet search revealed the term "keybot ii" but not in connection with my problem.
Searched "keybot" in the motherboard manual and found out that, that port is connected to a special "keybot" chip, and if the button on the motherboard is pressed, keybot functionality takes over that port. Opened the case and saw that the "keybot" LED was lit up. Pressed the "keybot" button and the LED turned off. Booted the machine back up, re-inserted the keyboard into that port and voilla! Logoitech G Hub now see's the keyboard, even in the port it used to not show up in.
The motherboard is a Maximus VII Hero for reference.
Mostly posting this for anyone else who might run into similar problems.
Cheers!
Cheers!
