- Sep 12, 2015
- San Antonio, TX *aka hellsville*
O.O
whats for dinner.....sauteed CPU with a splash of TIM.
Lapping not worth it... You void the warranty on the CPU (bad for resell value) for a couple of degrees that won't allow any higher clocks anyway...
Kenrou;7866518 or the confidence to use a blowtorch on a 8370 . [/QUOTE said:again not trying to push you ( well maybe a little, just cuz I think deliding is awesome) but a blowtorch killed mine. Solder is holding it there right? heat it with a soldering iron! Also you will need desoldering wick to remove the rest of the solder once you get the IHS to separate. Much easier to lap the IHS when its been removed. keep in mine Ive killed 2 chips Also Ill stop spamming about it, Im just trying to point out how easy the process can be. Anyone catch the videos about the vice method? great for non soldered chips and as simple as it gets
I have yes, but problem here would be to re-solder or glue the damned thing back together, Intel boards afaik have clamps to hold the CPU in place, my CHV doesn't
The FX has many little resistors just inside the lid that can easily be dislodged with a razor if you don't know what you're doing. Cutting the PCB is another sure fire way to kill it.
I know it can be done, I've done it http://www.overclockers.com/forums/...Putzen-Round?p=7696284&viewfull=1#post7696284
I just wanted to point out that the FX is different take a look and see how close those things are to the glue. It wouldn't matter what you used to cut the glue you could still knock them loose. http://classicplatforms.com/forum/viewtopic.php?f=200&t=8680
