- Jun 1, 2008
- Thread Starter
- #21
Short answer=NO
It will not even the core temps. A few degrees difference is nominal between cores.
Lapping will only flaten the surfaces of the heatsink and cpu IHS. Lapping to a mirror finish does more harm than good. if you want flatness, be sure to at least leave the surfaces a tiny bit dull. This will help in the bonding of the heatsink and cpu with the thermal grease, thus ensuring better heat transfer.
results may vary.
ive seen a 3c average drop in temps..both cores and cpu. the delta between cores has dropped to 3c-5c now.
could not be happier was alot of fun too!
