Hey guys I'm pretty new here on the forums so I wanted to take a second to introduce myself and show you my build. I also have some questions about overclocking my AMD 965 BE. I realize there are two other threads already actively talking about how to do this, and I am watching those as well. I built my rig a little over a year ago and have been adding bits and pieces to improve it over time. I just recently installed the H220 unit and now that I am no longer working with the stock cooler I wanted to give overclocking a try. My goal for this overclocking expedition is about 3.8-4.0 ghz, with the water cooler I feel like that should be very attainable based on what I have read so far in this forum.
So first, I wanted to clarify the programs I should be downloading. From the other threads I have read so far I have seen that you guys recommend downloading HWMonitor, Prime95, CPU-Z. Are there any other programs I should download or need to know about?
I have monitored my temps using the Asus AI suite that came with the motherboard while playing games, obviously this isn't the best way to do it, so I was wondering if the best way to start overclocking is to run 1-2 hour benchmark with prime95 with everything stock so I can have a better idea of what my system can handle? Is there a specific order I should start the programs in? Obviously prime95 would be the last to start up.
My components:
AMD Phenom II x4 965 BE 3.4 ghz
Swiftech H220 Stock Water Cooler
Asus M5A97 Motherboard
Sapphire Radeon HD 6850 1GB
Corsair Vengeance 8GB (2 x 4GB) DDR3 1600
Samsung SSD 830 Series 128gb
WD Blue 500gb Hard Drive 7200rpm
SeaSonic M12II 620 Bronze 620W 80 Plus Bronze Certified
Corsair C70 Military Green Case
Above are two pictures of my current set up. My One other question for the moment is about cooling the case. At the moment the only fan I have set to exhaust is the back fan. The H220 unit is set up in push configuration so it is pushing air into the case, I also have two fans in the front of the case pushing air into the case. So I guess my question would be is the one fan in the back going to be enough for the exhaust or should I try setting the h220 up in pull configuration? Sorry for the lonnng post just wanted to give as much information as possible
Thanks in advance for any and all help with any of these questions.
My components:
