- Jul 17, 2013
Hi everyone,
six months ago I build a custom water cooling loop for my rig which works great, except it keeps on getting dirty.
The first time I filled my loop I put distilled water, Maythem Biocide and Maythem red dye in it. Looked good for some time.
After four months the liquid started to look opaque and not clear red anymore, but more of an orange / coppery color with small brown "dust". So I thought that might be some colorization from the radiator or the Biocide was too much. When I added it the PH scale wasn't the recommended "blue/green" color (PH 7/8), but quite on the red side (PH 5). Afraid of corrosion, I started to panic and flushed the loop.
This time, being convinced it was the biocides fault, I left the biocide out, since the distilled water already is more on the red side PH wise, even without any additives. Maybe it doesn't matter, but at this point I added a LED flexlight to my build.
Now, two months later I started hearing my PC, which usually is dead silent. After checking the fans I noticed it was the pump. D5 on setting 1. It sounded like it had to work hard, like having to push against some resistance. Then I turned it up to max and the water flow was rather slow, almost looked "gooey"... and I saw that brownish particles dusting up in my res again. The fluid is opaque and orange/copper colored again, too.
So obviously this wasn't the biocides fault, but what can it be?
Corrosion? The dye? Plasticiser?
I use Masterkleer clear tubes btw.
Today I flush it again. This time without dye. But what about the biocide and the low PH?
I try to make some pictures. I don't see any green stuff for now, so it seems it's not algae either...
