Anyone running his loop only on distilled water?
I use only distilled water and a kill coil/silver bullet (only one is needed).
My build here
Iheard food colorant is not as bad has anyone tried dies? does it behave the same?
Food coloring is good for feeding all kinds of plant life in your loop.
Just so you're aware, I followed the development of Mayhem's dye and Mayhem himself acknowledged, during that process (I'm not sure what happened once he was marketing it) he himself acknowledged that it would settle out of loops just like any other dye. His goal in creating the dye was to get rich color unequaled by any other dye, and he achieved that at the time. His goal was not to prevent the dye from settling, it performs about average on that front. I can try to dig up links if you really care to read about it, but it's been a while.
I don't know... I must have missed that post.
Still... When I was researching Mayhem's dye almost everyone was happy with it and told how it is the only dye you can use without any problems like the feser or other ones.
Mayhem himself wrote in another forum that his dyes don't gunk, stain or flake.
Now I don't know what to make of that, if my problem really was the dye.
Certainly looks that way, giving that everything was clean and there were no "fishy" smells.
Regarding biocides I read that the use of silver is not recommended with nickel plated blocks (corrosion). And using PT Nuke or Mayhems biocide just ionizes the water even more and is not that great of an idea as well.
Running distilled water alone and changing it every 2-3 months should be save enough to prevent growth without using additives.
the dirt are already in there as soon as you press the start button, the color just make it colorful, and for the eye to become visible, and build up in the sinks
if you dont flush the tubing before installing it, you got a dust bonus right away. just an example
tubing, jetplate, blocks, rads, fittings+ more
Ther all are dirty out of the box..
Coolant isnt to blame, and you eye cant catch the small particles in the loop
and the diluted water is conducting electricity just fine, after a few minutes in a loop like that..
often people find crap in the cpu block, and its colored in the same color as the coolant.. Lets blame someone? feser, mayhem?. If you the is clean that crap wont build up in the first place..
Just some input..
i am saying that often there can be other reasons to the gunk phenomena, than the first impression.
This case i dont know about, how could i?
I shop at the micro center at Marietta, GA. do you?
