- Nov 10, 2012
- Ankeny Iowa
For good budget fans Yate Loons are good and Helix too ask jack
(rule of thumb, no one go nuts with this like people have with the 120.2 per block rule of thumb).
Sorry ATM for going off topic. Please forgive me.
It's worked for so long. Sorry I won't force people to sit there their first time freak out and get frustrated getting exactly the numbers you want to see. My personal advice to people is 120.1 high FPI or 120.2 for low FPI. If you disagree than so be it. I won't argue or get in a fight with you about it. But you've been making statements about this rule and has gotten a bit out of hand. I get with what you're saying but not everyone has the math you have to break it down and get exactly the heat surface needed. That's like telling people you do the math on the static pressure of a fan or pump head pressure of a pump with out specs from the manufacturer. Tests are done by people like skinnee and martin. We than get an idea of how much a standard 120.3 can handle for example. I been using this rule with Con, ED and many others for the past few years and worked great. To be honest if I recall correctly the "rule of thumb" saying from them when I first started. The end result spoke for itself. Don't take this personal but the last few weeks you've been in an all assault on that saying. It bothers me when I give advice to others only to have you say you're wrong. Than I will put a hold on my assistance to others if I am giving the wrong advise.
I use those Swiftech 8-way PWM controllers as well. They're pretty cool. Plug the PWM into the mobo and the 4 pin to a molex on your PSU. I use two of them, one for my four side fans, and other for my six fans for my push pull.
I just got a bit annoyed and thought that was directed towards me when in general you were just messing with the whole "rule". Like I said I get with what you're saying. Con has gone both ways. Used the rule or made the guy do the math. Maybe you did start it. Well than its your fault! lol
You do have a point with those forums. At OCN, you have people see a watercooling image and go spend thousands. A lot of things I would mainly disagree with with the way they do things there. Its too busy there and too much going on so you can't catch or help it all. Its like kids in a candy store without a parent in the building. Someones going to get hurt in other words.
No hard feelings here as I'll just leave the rule out from now on and get folks to do the math. Anyways, I'll change my ways. Again, I am not mad at you.
Before I end this, I'd like to cause attention to the water cooling stickies. Not picking at you but since you know all the editors etc, if someone can remake the stickies. There's things everywhere it feels like with a good amount of old info etc. Would love to see you bring some attention to it to the others from all the things we've learned over the years and to simplify the terms, in laymen terms if you will, for those to better understand. I even remembered I had trouble with it at times years ago when I first started. A simple thread with links to the stores is all it needs. Can't wait for that Skinnee calculator.
Yeah, I'd looked at those myself just for rearranging a few things and just have never purchased one.
Yeah, I'd looked at those myself just for rearranging a few thing and just have never done it.
They look like a pretty nice setup.
It should also run 3 pin fans too right?
That looks just like the fan hub in the primo case
The one in my primo lets me adjust fan speed via a pwm connection just like the one you posted
