- May 11, 2004
- Montana tech Butte mt.
The difference in size between 8mm and 3/8" is about a 1/16" so yeah there isn't much difference between them.
The difference between 3/8" and 1/2" is about twice that though. You end up with a fair amount of difference between them, is it always measurable with a $.05 diode? no its not and part of that depends on the block and pump you use. A storm and an Iwaki RD30 are going to probably show you a couple of degrees between the two. However, you might only see one degree difference on a Apogee and an Ehiem 1048 just becuase of the difference in restrictions and pressures in the loop.
Also GPUs tend to heat up your loop very well, even running a Bip3 with over 300cfm going through it I still was 2 or 3 degrees hotter on my CPU than with just the CPU in the loop. So I have to say if you have a spare loop then use it becuase two GTSes will put out more heat than your cpu anyday. (unless your running dual duals or quads).
My thought on your setup would be if you don't want to buy a buy a new CPU WB then don't, Robotech at syscooling did a test a while ago that showed a Maze 3 was within 1°C of a storm on an IHS loaded CPU.
As far as setup I would go 1/2" all the way and setup it up as two loops like this.
loop one.
Maze 4 CPU
Chipset block (the MCW30 is a good choice I would stay away from the maze 4 though the Acrylic top breaks fairly easily.)
Mag2 LE
single HC or if you feel like upgrading it looks like you could put a double in there.
Loop2
GPUs
Ehiem or if you don't get the mag the strongest pump
Double hc.
loop one.
Maze 4 CPU
Mag2 LE
Loop2
GPUs
Double hc.
