Asus z170-z i7-6700k @ 4.7 1.320v. DDR4 2133MHZ
Hello, i want to decrease cpu temperature by lowering ram voltage. Stock RAM voltage is 1.2 v i have tried to lower it down to 1.150v and it decreased my temperature from 82/84/84/76 package= 83 down to 77/82/78/75 package 78. So around 5C down just by tweaking RAM voltage. This will give me a temperature headroom to achieve 4.8GHZ on my cpu. My goal is 85C max during ITB stress test.
So the question is how can i check if my voltage is stable? So far i run memtest86 and passed with 0 errors. Will memtest86 give me an error if my voltage too low?
Some people say its bad to run RAM at low voltages,is it? is 1.150 considered as low?
And finally is it good idea or bad? If intel XTU or HWmonitor are accurate in reading temperatures then 5C decrease in temperature, isnt it great?
Hopefully you can understand what this thread all about, thanks!
EDIT: Updated screenshots and settings in BIOS to manual voltage for current testing.
Core/cache 1.300
RAM 1.150/1.250
VCCIO 1.000
Agent 1.100
PCH 1.100
CPU SB 1.000
HWmonitor above 1.15V RAM voltage, 1.25V bellow RAM voltage, other settings remain the same, Fan speeds are on max during testing. Also want to point you that not all cores get effected the same way, looks like core 0 and 2 has the most impact from RAM voltage!
Core/cache 1.300
RAM 1.150/1.250
VCCIO 1.000
Agent 1.100
PCH 1.100
CPU SB 1.000
