I have an amd Fx6300 and an Asus M5a97 le R2.0...First off, update the BIOS via thumb drive fat32 format from Asus's driver website with the latest drivers offline so you don't corrupt the BIOS which better supports fx chips because people are most likely on all your computers as this board doesn't sport a vrm...Install the latest version of Ai Suite II!!!!! For a heat sink, you will need to go water cooling if you want a decent overclock. I personally use an older Corsair H80 water cooled heat sink which I will eventually modify when my back ordered cable comes in (funny). You don't just throw it together and start overclocking it, it requires the right downloads and updates, and supported cooling for this processor you can't expect alot from a four pin. Trust me, this motherboard is durable. If by some miracle you ended up breaking this board, you must have assembled it wrong, or didn't line your memory up or put the voltage over 1.40 or something. The bios is so easy to work with it isn't complicated...There are like 5 more options lol...Also the same uefi bios the sabertooth uses. I am able to clock over 4.7mhz stable....Uhm, I forget what I set my voltages to, yeah...Sorry. Anyways enjoy the board,
