voigts said:
I am assuming this is something you are making for someone Sprocket? Do you have any pics of this pump/res combo you are working on? I thought the radiical top was for your system.
Oh no, Sprocket is my PC and the Radical top/pump is for her.
I killed 5 hours today trying to design/fit a pump/rez combo before giving up and reusing the Swiftec mini-rez that was in the old loop.
This round of mods involved replacing the 1/2" Tygon with 3/8", swapping out the Storm (rev.1) for an Apogee, replacing the Maze GPU with the Stasis Thermal Neptune and the MCP655 pump with the MCP355/Radiical top. Also, the Maze chipset block was ditched in favor of a Jing-Ting Chipforce heatpipe cooler.
Whew!
I did replicate your flow test however.
At least the modified top part.
I ran it once just to prime the pump and get my timing set up...don't have a stopwatch so I had to use an atomic sychronized clock, but the results of the next three runs were all within a second or so of each other so I think I got it pretty close.
2 gallons in 48 seconds.
The second run was 46 sec., but I'll settle for 48sec. as an average.
So, 150 GPH give or take.
This little hummer
rawks!
Best of all, the annoying high-pitched whine of the MCP655 is completely absent.
In the second shot you can see that the pump sits edgewise, the outlet pointing straight into the radiator inlet. The tube from the reservoir to the center of the Radiical top is 1/2" to ensure sufficient flow to the impellor.
Even with the 90degree fittings and the smaller tubing the flow in this loop is noticably stronger than the old loop.
Losing the northbridge block and swapping out the Storm for the freer-flowing Apogee probably accounts for this.
So far, CPU and GPU temps remain identical to the large-bore setup but the Jing-Ting is not as good as the Maze4...NB temp has gone from @27c to 40c.
Edit: Apparently my NB fan header is dead. Moving to a functional header has dropped NB temps to the low 30's. Still not as good as the waterblock but much more acceptable .
