What? Are you serious? You water cool and you don't know why a clamp is on a pump?whats this metal clamp everyone has on their pump for? do you put it there yourself?
AngryAlpaca said:The clamp is for the purpose of stopping leaks between the barb and the tubing... It has nothing to do with a cracked housing... It's used (or should be) on every joint in a WC system.
no so noisy for me. I am using 3/4 ID(inlet) and 1/2 (outlet)shikata said:i think he was referring to the large brass/copper tubing that appears on overbrazil's post/pic
now a few questions myself, i am currently using a smaller pump from petsmart, saw that they have the mag 3 for 45 (online only), and am interested in getting the inline, (current one is submerged in my waterfall rez).
could anyone list suggested things to buy at teh same time?
also i heard someone say that it was loud? is it volcano loud?... 48 db that is... or is it more like a hum?...
and you are all using 1/2 tubing right?
much obliged...
AngryAlpaca said:What? Are you serious? You water cool and you don't know why a clamp is on a pump?
Someone asked about "crass barbs" and I'll just assume that that means brass barbs, and they're more likely to crack the casing of the pump.
much obliged...
DarkDraco said:ive been using a hydor for some time... just recently ordered my mag3 and it hasnt arrived yet.... i wouldnt know... thats why i asked
not so much, i have just put some foam under the pumps.It is incredible, but the EHEIM is louder than my mag.Korndog said:i would say it is about 30dba. i can hear it over my 21dba panaflos, but it blends in with my 25-30dba blower. noticible, but if ur using any fan over 30dba, u shouldn't hear it.
overbrazil, i used to have my inlet as 3/4 and my outlet 1/2 like urs. my was still a little loud and would vibrate a lot. when i switched to 1/2 and 1/2 so i could accomidate my reservoir, it didn't get louder or start vibrating more. did u do anything else ot make it quieter?
shikata said:oh well, it gives better head :-d
