Here's the "udder" one I was thinking of.
Editing your Web browser's settings for faster loading of pages.
According to the HTTP specs, only limited number of simultaneous connections are allowed, while loading pages. To increase that number, add the following entries to the Registry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings
"MaxConnectionsPer1_0Server"=dword:00000020
"MaxConnectionsPerServer"=dword:00000010
Alternatively, you can download a patch that will add these entries for you automatically, look for our Web Patch in the Downloads section of the site. (
http://www.speedguide.net/downloads.php)
The above tweak (and the web patch) works with Internet Explorer versions 4 or newer. For further reference, here check the MS Knowledge base: Q183110 - "WinInet Limits IE connections per server" .
Firefox Web Tweaking
For those that are using Mozilla's Firefox browser, the same tweak of increasing the number of concurrent connections per server can be applied as well (although they are already set to a more reasonable value of 8). Here is how.
In the address bar, type: about:config and look for:
network.http.max-connections-per-server
You might also want to take a look at the optimized Firefox and Thunderburd builds here: Moox.ws
Note: There are some other questionable tweaks, for example: You can enable "pipelining" by setting network.http.pipelining and network.http.proxy.pipelining to "true", and changing network.http.pipelining.maxrequests to a number like 30. It can, however, prevent some pages and images from loading, and is not recommended.
Hope this is what you were looking for.
