Here's the loop:
Fedco 2-342 (Four AOC Aluminums) -> MCP600 -> Maze4-1 (172W Peltier) on GPU
There is a lot of heat being dumped into this loop by a peltier cooling a hot GPU core.
I currently use four 25mmx120mm thick AOC Evercool Aluminum fans (0.38A, 85CFM), but I am considering switching to two 38mmx120mm fans (likely big Deltas or Sanyo Denkis). The 38mm thick fans I am considering would be putting out around 100cfm-160cfm on full blast, and with much more pressure than my current 25mm thick fans.
Due to space restrictions I cannot use four 38mm thick fans unless I modify the case front a great deal.
Which would provide better performance for my loop, on 12V going full blast? Noise of the larger 38mm fans is not an issue, because I can put them on a rheo for day to day use where extreme airflow and pressure is not required. I am thinking of switching to using only two larger and more powerful fans so that I can crank them up for benching to maximize the effectiveness of the loop. Will there even be a benefit over four AOC Aluminums on 12V?
The loop is cooling a 172W peltier on a graphics card core, and during benching the loop tubing, block, and radiator are all still very warm to the touch even with my four Evercool Aluminum's on full blast. That tells me that a beefier airflow setup will have a large impact on the peltier coldside temperatures I see.
I want a very effective setup that will get my GPU as cold as possible. Since I can resell the fans I currently have, cost is not a huge factor in switching fans. My question is whether switching is worth it. Also, how great would the benefit then be if I used four 38mm thick fans instead of just 2 with all on full blast (I know how I can fit four 38mm thick fans although it would be a bit of a hassle.)?
Should I grab some larger fans?
