Overclocker550 said:
his ti4400 was stock and his cpu was slower than mine. I get twice the fps he does cause my cpu and ti4200 are heavily overclocked. Youd need a very exceptionally good overclocking 9800 pro to be twice the performance of my overclocked ti4200 and I dont have $1000 to go looking for 5 9800 pros and besides ill be cpu limited so I wont get twice the fps except maybe in 2048x1536 but at 1024x768 my ti4200 isnt chugging at all so id get maybe 50% more fps with a 9800p at best.
well said OC550.
but there is no need for you to drasticly look for a great OCing 9800pro....
just get your hands on one, and you'll see that your belief of 50% performance increase with the new card, is more like min then max....and I'm not even talking about OCing the card yet.
about 60% would be for games like far cry, UT2003/4....
about 80% would be for games like deus ex:iw, sw:kotor
(plus you'll have all the DX9.0 eye candy, and some *cough* AF and AA for free *cough*)...and I'm mostly talking about a res of 1024x768
the 9800pro won't be an out right, bad card to have with the A64 system you might build in 2006....
and getting a 9800pro now will still be cheaper (and give you much more performance) then building a whole new A64 system in 2006.
using your own words as a bases of performance increase;
I just can't see you spending about twice the amount of a 9800pro for an A64 system, to only get about 30%-40% increase in most games(with that ti4200).
while I'm not telling you that you have to upgrade anything at this time....
please rethink your upgrade path.
you seem to be basing your thoughts of the 9700/9800pro (performance wise) as if they would be running on slow CPUs...
and that is something that you "don't" have.
while you may not have the fastest system, your system is more then fast enough to run a 9800pro quite well.
and the best news is, if your able to OC that system of yours a little more then you'll get even more performance out of it.
getting a 9800pro (over a faster system) is basicly a no brainer...
I can almost hear it in many of your latest replys.
mica
