Hi Guys,
I am a complete layperson when it comes to PC's but wanted to ask a question I am sure you will all be able to answer.
I had a noisy fan in my PC, which was custom built for me a few years ago. It was a top spec build at the the time, and other than the fan starting to buzz a bit, it was perfectly fast etc.
I decided to fix the fan and called a local PC repair guy who came out to review the fan- call out fee was 150quid - he said the fan in the CPU was the culprit and gave me a link to buy a new CPU about 60quid. He came back to install it - 100quid, but it took him a good couple of hours as the PC kept shorting when he did the install - he was bemused, calling his co-workers etc, but eventually he seemed to crack it.
A couple of weeks later, I switch on my PC, doesn't boot. Monitor goes through some cycles, keyboard lights up, mouse lights up, and then monitor goes through some cycles etc...and it keeps on this same loop.
I call the guy back out - he spends another 2 hours, playing in the BIOS, calling co-workers etc, before declaring the Mother Board is the problem. I ask if its related to CPU install, he says 'NO', just a coincidence that it failed at the same time.
He gives me the link to buy another MB and a quote of 200 quid to install it.
So my question is, did the CPU damage the MB? is it a coincidence, can anything be done? etc
I have a feeling fixing a noisy fan is going to set me back a new PC :/
Thanks!
Thanks!
