MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130661
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231468
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113280
Test 0 : 0
Test 1 : 65535+
Test 2 : 65535+
Test 3 : 65535+
Test 4 : 65535+
Test 5 : 65535+
Test 6 : 65535+
Test 7 : 65535+
Test 8 :65535+
Test 9 : 65535+
Test 10 : 65535+
These are my results approximately, 5 hours into the test. (testing both sticks)
What do I do now?
I checked MSI's website (for my mobo) and the RAM I am using is not listed under "compatible memory" so does that mean it will never work? If it wasent compatible, wouldn't my computer not boot up at all? I can get into BIOS...
If that's the case, how can I test my RAM to make sure it's not faulty? Since it's not compatible? I don't want to return RAM that is fully functional.
Test 0 : 0
Test 1 : 65535+
Test 2 : 65535+
Test 3 : 65535+
Test 4 : 65535+
Test 5 : 65535+
Test 6 : 65535+
Test 7 : 65535+
Test 8 :65535+
Test 9 : 65535+
Test 10 : 65535+
What do I do now?
