- Jan 12, 2013
- Colorado Springs, CO, USA, Earth
So today I swapped out my old GTX 690 with an RTX 2060 Super. Used DDU and did a clean installation. But I'm left with these two mysterious drivers with yellow exclamation points by them, one says it's a "PCI Device" and the other is a "Universal Serial Bus (USB) Controller". What are these? Do they even matter? I installed the Gigabyte software that the card is supposed to come with that allows you to control the fan speed and LEDs, and although it works, the drivers still seem to be missing. I'm using Windows 7, does that matter?
Both of these seem to share the same hardware IDs:
PCI\VEN_10DE&DEV_1ADB&SUBSYS_40091458&REV_A1
PCI\VEN_10DE&DEV_1ADA&SUBSYS_40091458
PCI\VEN_10DE&DEV_1ADA&CC_0C0330
Thanks!
Thanks!
