Or, skip the middleman and try a fresh install media...I will try linux.
https://www.microsoft.com/en-us/software-download/windows10
I'm paraphrasing... Your baby is ugly, clean that *%$ up!
That'd be a kick in the nads if it was just a bad install disk.
57C Prime? Blend? What program are you reading temps from?All drivers installed. Prime for 20 minutes with CPU temp range 48 idle 57 max.
Gonna turn on XPS.
I'm also doubting those temps.
Unluckytry to find a different version of Win10 to install. On my Z370 I initially installed an older version of Win10 and the network driver didn't function properly, on a newer Win10 it worked fine.
Is that a rule of thumb or is it based on some advice specific to the R5 3600?It should throttle at 95C... so under that.
Well, that's better than "I told you so" which, much to your credit, you did.Unlucky
Eh, it could have been bad ram, bad ssd, bad cpu, bad gpu, bad mobo, could have been anything really. That's why throughout my posts here I tried to point you what things you can rule out. I'm just glad things are working out for you now.Is that a rule of thumb or is it based on some advice specific to the R5 3600?
I installed the new case fans so I need to play with the curves.... Dare I say playing with curves is my favorite?
