Most important question is:
is it an upgrade or a new system needed to be build ASAP.
If it is a new system AND is willing to spend an extra $150-200, then a 754 system 250 GB system is a good choice for 20-30% performance gain (over overclocking mobile Barton/Tbred B).
Also that 20-30% is an estimate, a guideline, since performance varies depending on actual programs run, exact memory and system setup, and many other things.
If it is an upgrade for an existing system, say nforce2 + Tbred B/Barton, and one may wait until later this year, hoping for price drop and cheaper 939 CPU and system (no guarantee). These are all economic considerations and tradeoff one has to make based on particular need, ....
For video editing, encoding, rendering, memory bandwidth helps performance a lot, hence 939 and FX-939 would be preferred. But that depends on budget and price-performance consideration, so only the one who builds the system can answer these qusetions.
For performance numbers for the various system, they are detailed here:
Typical Overclocking System
Performance analysis of various A64 systems
