- May 15, 2010
- Euroland, Denmark
Hey guys,
I have just ordered myself a few liquid ultra's. I will be delidding my 3770K.
I have been reading more and more success stories about delidding these cpus.
I have come to one conclusion. It works! But i have noticed that people doing this, spend a lot of time cleaning the CPU's, the glue that has been used to hold the IHS in place, and this is not replaced.
I noticed, that the inside of the IHS of course houses more space then the cpu chip needs, in my mind this is pure air.
If there was a possibly of air to get out from inside the IHS, would this not improve the cooling improvement further?
Here is my idea explained, with my mad paint skillz.
Lid untouched.
This is where i would use a very tiny drill (1mm/2mm), and make 4 holes. From my point of view, this would help heat get away from the chip. It my not be big, there may not be an airflow, but in my mind it would let heat get away.
I plan on trying this on my 3770, the lid will also be lapped. Since the Liquid ultra isnt cheap, and i have no idea if i can take the chip apart after using it and testing, i am unsure if i can run a delidded and lapped test, and then a delidded, lapped and modded test after.
What are thoughts on this?
Lid untouched.
