More hopeful 1.0A experience...1.5 Ghz
I just got my Celeron 1.0A today. This is a Phillipine chip made in week 51 with a pack date of 12/18/2001. The default voltage is actually 1.475V despite it being said that they would be 1.5V (Oldfart’s was 1.475V as well).
For cooling I used the Millenium Glaciator and Artic Silver II. The mainboard is an ST6 with Mushkin REV3. I did the wire trick right from the start however the wire must have come off by the time it was mounted in the socket since default voltage showed as 1.475V and I could only adjust it up to 1.6V. All voltages and FSB that I mention are according to what was set in the BIOS rather than the true reading from CPUID and HW Doctor.
I first tried 133 FSB at default voltage and it booted into Windows (WIN98SE to be more specific) without problem. I ran Prime95 for about 5 minutes and everything seemed OK. I didn’t test it more thoroughly since I knew I would not be leaving it this low. I then tried 140 FSB at default and it would not load Windows. I didn’t want to play around with the voltage that much so I then went straight to 1.6V (the maximum I could go without the wire trick) and she booted right up at both 140 and 145 FSB. I ran Prime95 for a few minutes but didn’t do any thorough stability testing. I then went for 150 FSB at 1.6V and it would not load Windows.
I figured I could go higher with more voltage so I took the chip out and did the wire trick again and made sure that the wire was a little bit tighter this time. I then tried 150 FSB with 1.675V (the new default after wire trick) and it would run Prime95 OK but HW Doctor gave some type of illegal operation error and Sandra2001te crashed before even loading. I then upped the voltage to 1.7V (HW Doctor actually read this as 1.72 – 1.73V) and Prime95 runs OK and both Sandra and HW Doctor ran without those errors. I then ran Q3 demo for about 10 minutes and had no problems. Max temp under load was right around 35C.
Just for the heck of it, I tried 160 FSB and 1.8V but the system restarted right after posting. I guess the top speed is going to be somewhere between 1.5 – 1.6 Ghz. I will test some more and let you know how high I can go.
