Still on the fence about which CPU to buy but from what I understand, both CPUs are socket 1150 so either one should slot in to the same motherboard, right?
At the moment, I'm looking at an Asus Z87-PRO Intel Z87 Socket 1150 Motherboard but the page says it doesn't do crossfire. Is this true?
I'm planning to OC the CPU --- find the max stable OC then back off a bit. I'm not going to squeeze out every last ounce of performance, but I will try a "medium" OC and if the performance gains (FPS) is good, I'll keep it at the OC but if not, I'll probably run stock or low OC. I have a CoolerMaster Hyper 212 Evo and Kingston HyperX 1600 RAM from my current PC which I hope to use with the new one.
Having said that, I wonder if I can save a bit by buying a lower-spec board? I've only gravitated to the Asus because of the reviews I read but to be honest, most of the "specs" are gibberish to me so I just look at the charts and read the conclusion/final word section
I have two SSDs and two HDDs, one HD 7970 GPU, and a DVD-burner so nothing exotic. I am contemplating trying out a Corsair H100i Performance Watercooler but that's it.
So, does anyone have anything bad to say about the Asus Z87-Pro? Is there another motherboard that I should be considering?
I've tried to read up on reviews but the review for the Asus is a good few months old so I wonder if there's anything newer/better?
Thanks!
Thanks!
