- Apr 22, 2002
- Folding@Home in Ball Ground, GA
FYI - I had originally installed Ubuntu 8.10 by mistake and not 8.04. So I deleted the 2 VMs on my system and then followed the directions in the first post in order to install 8.04. A few things I would like to point out to any beginners trying to follow these instructions, specifically with regards to copying the VM files from one directory to another:
After you copy the files and then create the new VM by browsing to the second directory, VMware will not ask if you copied this VM until you try to start the second VM. At that point, it will ask if you want to create a new machine ID.
Before you start the folding clients, you need to change the Network HOST name for the second VM; otherwise, both VMs will have the same HOST name (since you copied the files). You can change the HOST name by starting the second VM and going to the System > Administration > Network. When the popup appears, click on General and you can change the HOST name for the second VM. You must reboot the second VM for the change to become active. If you do not change the HOST name for the second VM, you will not be able to see both VMs via Windows Network Places.
One last thing I would like to point out is that when you SHARE the "folding" folder, it will automatically install Samba. However, you must reboot the VM for the shared folder to appear in your Windows Network Places.
