- Mar 14, 2013
- Massachusetts
Hey all, I just got in three Gentle Typhoon AP-15 fans that will be used for my next water cooling adventure. I will be adding another triple radiator to my build which will have the three fans.
As we all know, the AP-15s are not PWM. 3 Pin fan controlled via voltage control. My mobo (Asus P8Z77 WS) can control both 3 pin fans and 4 pin fans. PWM on 4 pins obviously, but I believe it can also handle voltage control on 3 pins as well which I believe so because I have a Noctura 140mm 3 pin for my exhaust. My question is, is there a SAFE way to drive multiple AP-15s from the same header on my mobo?
Note, it doesn't HAVE to be on the mobo. Its preferable so I can get the RPM readings, but if I needed to have an external controller, not a huge deal. Maybe a PCI bracket one or something like that.
What do all you out there who use the AP-15s do to drive em?
Thanks
Thanks
