- Feb 7, 2005
My question is a simple unless you don't know how to set them up. When in doubt I come here and ask you guys and learn at the same time.
I considered buying a SSH but I think that will be on my next build. I know most you your opinions,that I spent too much on what I didn't need and not enough on what I did need...lol
I guess we all live and learn.
The cooling on my Case has a lot of fans, 2 on the top of the case,one on the back,one in front of the HHD slide in hard drive holder.
I also have a huge fan on the side cover it has to be 8 to 10 " in circumference
All the case fans have the bigger 5 pin connectors that I have always just connected the 5 Pin connectors to each other and then connected all of them to a 5 pin power from the PSU. Besides being easier to hook up is there any advantage to buy the converters from big connector to 4 pin smaller connector.
All my fans that came on my case which are the 2 top,1 back and the verylarge fan that is connected to my side cover all have manual fan speed controls.
Thanks
Ron
Thanks
Ron
