I finally got the system up and running over the weekend. Ive got new pics but Im at work right now.
The loop consists of the two towers in parrellel, a magdrive3, and a MCW6000a, nothing else.
So the heat load isnt large. The mcw6000 is cooling a barton 2500+ OCed to 2ghz.
Lastnight my ambient was higher than normal, 27-28c. I initially had the fans on full when I hooked everything up. I was affraid the coolers wouldnt cool the barton enough. At a 28c ambient full load temps stabilized at 51c. Stayed there for about 2 hours then I messed with the fans. At first I had them in parrallel then in series with a pot. Then I put everything in series, giving each fan <5v when I turned the pot all the way down. At this speed you cant hear the fans unless you put your ear to them and they are moving little to no air over the coolers...
To my surprise temps rose a whole 1c...
I was sitting there watching the temps for another 2 hours waiting for them to go up but it just stayed at 52c. Now mind you this is with the mobos diode so I know temps could go 10c either way but thats usually constant.
Since the fans werent moving much air I thought "heck I'll just turn them off." With fans completely off temps hit 55c and stabilized after an hour.
The room it was in was pretty stuffy and much hotter than the rest of the house. The living room it will be in is always cooler and very open so Im pretty sure IM going passive with this. I have a eheim 1048 coming in the mail because I think the mag3 is putting too much heat into the loop. I'll see how my temps do with the 1048 with the current fan setup. If there isnt much change I'll go fanless.
Either way IM very happy with it. if I go fanless I'll feel I wasted the effort with making that shroud and fan mount but ho hum.
And one note to myself for being an idiot I routed the tubes to pump water up a tube then down into the coolers. Tons of air gets trapped that way. I should have pumped the water up the coolers then out those top tubes you can see in the pics that are connected via a wye fitting by the fans.
