- Dec 1, 2007
- Near Toronto Canada
Yes I just downloaded the latest version. Any idea what the version number is that I should be using? I won't be back home until tomorrow to try again.
Ya that's the problem then. Not familiar with P95 version numbers. There are alternative programs for stress testing like AIDA64. Regardless, if you made it through the whole night in P95 blend then you have a stable OC.
At this point, you can either reduce the vCore and stress again, gradually going down until you find the lowest vcore that this OC is stable at. At that point you should bump it up just a couple of mV and leave it. Or, you can try for a higher OC on your current vCore.
You should check your max temps in intensive gaming, content creation, and whatever else you are using your PC for, as these are more "real world" scenarios.
Somebody will be along soon I'm sure to let you know which version of P95 you should be using. If you don't want to wait PM either ATMINSIDE or EarthDog and they can tell you what it is and where to get it.
