I swear I'm not a spammer. Just excited to share this creative mod that I did this weekend. I've posted it on a few of the other forums I'm on and have gotten a pretty good response. Hope you guys dig it as well.
A few weeks ago, there was a link to a youtube video where some folks painted a car with some color changing paint. I really liked the idea, and wanted to mess with the concept. Messed with a few test pieces, and then decided to pull the trigger. Before I go any further.. I'm not really a case modder. I usually buy barebones cases for my needs. By day I'm a SAN admin. By night, a dnb dj, and paint gun terrorist.
I went to Frys on Friday and picked up this case for about 35$ with tax.
Unboxed.
Unboxed
Tore it down, and took a perfectly good case and scuffed it up with some 600 grit paper. No turning back now.
Front shot.
Mixed up my basecoat. I used a 2 Oz of Nissan Metallic Silver, 2 Oz of Honda Accord Metallic Blue and 4oz of reducer. SpiesHecker for those that might want to know.
Here it is in the cup.
oh.. You want to see a video of the color being mixed?
I sealed the case with a black sealer, and then based on the case with the mixture above. The only way to describe the color at this point is blue steel. (zoolander would be proud). The lighting doesn't really show the color at this point.
I tried to do a technic called Marbling. I didn't get any pictures of it. I used a white pearl mixture. It didn't come out as bright as I wanted. But there is definitely some white pearl on the case over the base coat at this point. Next I needed to intercoat the marbling. I had some Black to clear color changing pigment. It turns clear at 84 degrees. I mixed a bunch of it with 4oz of just straight binder and HOK Blue Pearl to make it fancy. It ended up turning the case a gun metal color. Wish I got a shot of the that mixing. was very pretty looking.
After that.. I cleared the case with 6 layers of Chroma Clear. I got a decent amount of orange peal, but my shop temp was a little cool for the activator I was using. Nothing some wet sanding cant fix. I just finished the clear in these shots.. So there is a bit of clear coat mist in the air.
Another.
Another.
At that point I left it alone. And came back the next day.. Took it outside and took some outside shots in the sun.. Very gunmetal looking and that blue pearl looks amazing.
Another shot.
Oh, so does it change color or not? Lets find out.. I took the case back inside.. and took a shot of the front bezel. No color change.
Added some heat and Oh look! It does..
But WAIT! There is more! How about a video?
Then murphy's law struck. When putting the case back into my truck, the shocks holding up my lift gate glass suddenly let go and dropped on my head and my case chipping the paint.. =\
There is a fair amount of orange peal in the case, but nothing that can't be wet sanded out. I'll do something about the damaged paint chip. I'm giving the case a few days to further cure.. Then I'm going to try out my new Trizact 1500,3000, and 5000 grit paper on my detail DA sander. Then I plan to hit with my high speed buffer with 3m cutting compounds. That should beat that orange peel into smooth glass.
Anyway the idea here is 1. Can it be done. Yep, I did it. 2. A color changing computer case would be a great indication if your machine is running hot or maybe over heating. I think this would be a great idea for most of you guys running with extreme overclocks. You'll visually see your hot spots in your case.
Let me know your thoughts. I actually don't have any use for this case. I got it on a whim so I'm definitely willing to sell it. Make an offer and its yours.
Anyway, let me know if you thinks its cool, lame, stupid, awesome, or neat but just not for me?
Edit.. I searched the forum looking for people who have painted a case or looking for help.. If you need help with paint, I will also do my best to help you. =)
Unboxed.
Unboxed
Front shot.
Another.
Another.
Another shot.
