- Apr 28, 2012
- Mountain Home, AR
For those of you who aren't lucky enough to get a 1090t/1100t that will clock to 4.3Ghz and can only reach 4Ghz like me... there are ways of getting it to perform. After researching multiple threads, finding the right fsb/multi ratio, and getting the right HSF and TIM, i managed to pull some pretty nice clocks from the CPU/NB and HT-link.
Setup:
CPU: AMD Phenom II X6 1090T
Mobo: ASUS Crosshair V Formula - BIOS 0903 (Best for Thuban OC)
Ram: G-skill Sniper 2x4Gb 1866Mhz 9-10-9-28-1N 1.5v
Video: 2x EVGA GTX 470's in SLI @ 825/1650/2000 1.087v
PSU: OCZ ZX-1250W Modular 80+ Gold
HDD: 2x WD Velociraptor 600GB Sata 6Gb/s in Raid-0
HSF: Thermaltake FRIO with CoolerMaster SickleFlow Push/Pull
TIM: IC Diamond 7-gram 24Carat
Case: Cooler Master HAF 932
OS: Windows 7 Ultimate x64
OC Settings:
CPU Multi: 17X (3995)
FSB: 235Mhz
PCI-E Frequency: 105Mhz
DRAM Freq: 1880Mhz @ stock timings
CPU/NB Multi: 12X (2820Mhz)
HT-Link Multi: 12X (2820Mhz)
CPU LLC: Extreme
CPU/NB LLC: Extreme
DRAM Voltage: 1.6v
CPU Voltage: 1.475v (~1.525v Load)
CPU/NB Voltage: 1.4v
CPU VDDA: 2.6v (Helps stabilize higher FSB)
HT-Link Voltage: 1.2875v
NB Voltage: 1.225v (better VGA throughput)
PCI-E VDD Voltage: 1.126 (Increased 1 increment to stabilize VGA OC)
Temps:
Idle CPU: 24C Deg
Idle Chipset: 27C Deg
Load CPU: 51C Deg (So Far... currently running prime95 blend for almost 4 hours. I will updates these temps and voltages until stable as needed)
Load Chipset: 31C Deg
Like I said... I'm in the process of running Prime95. It's been 4 hours and seems very stable. Ht-link OC makes OS feel very snappy! I'm also going to run LinX at full memory capacity and upload screens, as well as HyperPI.
Setup:
OC Settings:
FSB: 235Mhz
CPU LLC: Extreme
CPU/NB LLC: Extreme
DRAM Voltage: 1.6v
Temps:
Idle CPU: 24C Deg
