RAM: Crucial Ballistix Elite 32GB (4 x 8GB) DDR3-2133 Memory
Yes I bought 4 sticks, each 8GB each, all separate. I hear what you're saying DNRDustin, they're designed to run "up to" 2133MHz. By saying "stock" I mean they're set to 1600MHz at default voltage of 1.5v. They're designed to go run "up to" 1.65v. Hope that clears that up for you.
Test results to come soon! I'm shutting down and pulling two sticks, I would expect to see the 5GHz!
For the record, nothing there shows 32GB. That is bandwidth they are talking about, not capacity.Here's the specs I was talking about for the FX 8350
Memory
Memory Controller Processor Integrated
Memory Bandwidth 128 bit
Memory Supported Up to DDR3-1866MHz Unregistered DIMMs
HyperTransport™
Bandwidth HyperTransport™:
Up to 5600MT/s full duplex on 16bit link
Up to 8.0GB/s HyperTransport™ I/O bandwidth or
Up to 16.0GB/s in HyperTransport Generation 3.0 mode
Memory:
Up to 21GB/second Dual Channel Memory Bandwidth
Total Combined Bandwidth:
Up to 37GB/s HyperTransport™ and Memory Bandwidth
Supports up to DDR3-1866
Supports low voltage memories of 1.35V and 1.2V
Up to 29.9GB/s memory bandwidth for DDR3
Pre-Fetcher improvements
Direct communications to each core in Dual-Core module (APIC registers in each core)
- - - Updated - - -
