Ahh a leaky chip like my FX 6300.
Well I will tell you now, hitting it with more Vcore won't help. I've gone up to 1.75v on AIR trying to get it stable at 4.7Ghz. No dice. Tried this again, hammering the voltage but this time on WATER. Still no dice.
There is a point where more Vcore doesn't make it stable, in fact it makes things worse. More heat..
In the end, I settled with the FX 6300 at 4.6Ghz @ 1.6v. Any less voltage and it fails prime95.
I love Vcore, so I take the risk running the 6300 at 1.6v all day, and I can confim that my chip has degraded becasue of the repeated hammering of voltage and the extreme temps I let it get to (85C package, 96C socket!)
My advice is to find a clock that doesn't need more than 1.55v which for you seems to be 4.5Ghz.
The only other option is to roll the dice with a new CPU, but honestly, unless you can get the new CPU to 4.7-4.8Ghz it's not worth the money preformance wise.
Sucks having a crappy chip, I know what it's like but hey, buying a CPU is like playing the lottery. You never know if you are going to win. Win as in a good high clocking chip anyways!
The issue is not whether the motherboard will support the high speed memory. The issue is the IMC (Integrated Memory Controller) on the CPU in any kind of a stable fashion.
Yes I bought 4 sticks, each 8GB each, all separate. I hear what you're saying DNRDustin, they're designed to run "up to" 2133MHz. By saying "stock" I mean they're set to 1600MHz at default voltage of 1.5v. They're designed to go run "up to" 1.65v. Hope that clears that up for you.
Which is why I kept them at 1600MHz. I've actually put a support ticket in to AMD asking about RAM in this situation. We'll see what they say.
So the next question from here is:
Can I put the power saving features back on like Cool 'n' Quiet etc with it OC'ed? I'd assume that it would jump around with voltages and speeds according to the load I ask it to do. Never done it before but it is a question I've had. Keep it set on High Performance settings or Balanced or Power Saving?
So to make sure I understand you correctly you bought each stick individually and not as 4x8gb kit. If this is the case these things may not play nicely together even at stock speeds.
