All of this is MEANINGLESS...
onix said:
NEW TEST:
I will idle my pc for more 1h. After that (if it will not freeze), i will install the GPU driver.
After i install the driver: (1) i will open the youtube video for 30min; (2) i will run the witcher (game) on medium and ultra quality.
Having a hard time understanding how much you know about computers. You bought a good and well capable motherboard but you can join the HOT crowd like another in the AMD cpu Forum section with a HOT FX-9590 cpu and not enough cooling that is able to get the heat out and away from even FX-9590 running at stock speeds.
You do not normally give two hoots about CPU temps in bios. The system is not under load and you are not booted into windows. HOWEVER the bios in your case shows the cpu is running too hot.
What we need to see is accomplished as outlined completely below and how EVERY other person for 3 years now has tested to see if they can even run their system.
This is what we need to see for sure and a real good starting point.
Normally during setup and testing we disable C1/E, C6, Cool N Quiet, APM, TurboCore and in windows performance manager itself we set to "performance" mode. ALSO if you have HPC in bios you would ENABLE it. That way there are not "other" settings messing with the overclocking process. Some of those settings are not available on all models of cpu but where in evidence we disable for setup of overclock process.
CPU Tab in CPUz from CPUID com
Memory Tab in CPUz from CPUID com
SPD Tab in CPUz from CPUID com
And this is screen capture of HWMonitor (free version) from CPUID com
HWMonitor has been scrolled enough and large enough to show Min/Max of Voltages and includes the CPU CORE TEMPS / "package" temps fully visible. Latest versions of HWMonitor show the CPU Core Temp as " a Package Temp" and is only shown as a single temp since there were never multple, individual core temp sensors anyway.
This capture is made of HWMonitor after it has been open and running on the desktop logging Min/Max temps and voltages while Prime 95 was running Blend Mode test on all cores for at least 20 mins and then the capture of HWMonitor was made and it shows the Min/Max temps and voltages before P95 Blend was started and while running P95 Blend mode and gives much greater insight into how the system is performing without guessing.
In order to attach screenshots of INDIVIDUAL images as suggested, first crop and capture the images with Snipping Tool found in Windows Accessories or equivalent. Then click on Go Advanced, a button at the bottom of every new post window. Then click on the little paperclip tool at the top of the Advanced post window when it opens. Clicking on the paperclip tool brings up the file browser/upload tool and the rest is fairly obvious.
I hate to say this but it surely seems as if you would have done far better in the overall scope of things to have gotten you an Intel system and not this hot running FX-9590 system and without some pretty good knowledge of what needs to happen with a hot cpu. Good luck. And if you cannot even start to run P95 in Blend mode then you are surely going to have slow down and take a long hard look at what is happening.
RGone...
