- Jan 7, 2005
Our OC Forums course "Dealing With Overclocking Disappointments" has been cancelled again. He'll just have to deal with it.
Congrats on that victory. I was think about thins when looking at the test you ran and thought, Hmmm I wonder just how much of this is true and just how far it has gone.
It would seem that for sure you cheery picked that test and even if you did not, I think that test is geared towards Intel / NVIDIA.
Why? One reason every time I have ever used it not only is EVERY SINGLE INTEL SYSTEM LISTED BLOWS AWAY every AMD (Amazing to me) other than the lowest end Intel offering at the lowest speed? Even aged at that!
Makes me wonder how much influence Intel really has. I ran Passmark and found that very same thing going on! I mean This CPU can hardly be THAT SLOW and bad Compared to Intel's OLD *** ****!
Seems like the VW emissions thing only with PU's.
I has a Q9650 and in almost every benchmark it comes out on top or so close to the Ryzen 3 1300X at 4.0GHz it makes ME SICK! What the **** is that if NOT favoring the Intel CPU or something else?
I commend you for obliterating my BRAND NEW Ryzen 7 1700 with your Ten year old CPU great job.
Why don't you promote that CPU? Why is it that you are not shouting from the top of the forums for all to see?
You should lay out **** tons of Benchmarks of you x58 against the Ryzen and obliterate the ****ING COCKSUCKERS FOR GOOD!
AMD slams “biased” and “unreliable” Intel benchmarks
Says SYSmark doesn't represent true performance, compares to VW emissions scandal.arstechnica.com
You were set up.
Already had a rough approximation of what the scores would be. Just wanted to prove a point.
You're lucky to have a Ryzen system. Enjoy it. I do not own one. I 'want' one, but I don't even use the cores I have now, so in my mind it is unjustifiable.
Thanks for being a good sport. A little mouthy.........but still a good sport.
There was no cherry pick. It is pure core count and clock speed. I had you beat on both. There are probably a dozen benches where this is all that matters.
Only reason I know is because I bench. You do not. The other benchers here knew how it was going to go.
Anyhow, sorry for pulling a P.T. Barnum on you.
How did you get kicked off?I got kicked off.
I'm an Azz?
